A Shadow of Itself
very effective image
Great image capture and PP. For my eyes…Does the mount encroach onto the shadow or were you hiding something you wanted cropped out?
Great looking B&W results and image. Did you use DF on this…if so, how did you get equal size matting proportions?
I’ve not been able to use DF for a while. This is an old preset of mine that I am able to invoke but not adjust. Not sure at the moment what we are supposed to be testing on Beta. Hopefully, that will change soon.
I just used the PR v1.8.5 on my Mac and the Frame/Mat proportions seem to be working ok on the PR version.
