Adding My Own Textures
How do I add my own textures into Texture Effects?
Hi Kathy,
Thanks for your reply, I have looked at the video but the screen you
show bares no relation to mine.I have attached a screen shot of what I
see when I open Textures.
Thanks,
Paul
The video shows Texture Effects the plug-in and it looks like you are using Texture Effects in Studio. The process is basically the same. See if the below screen shot helps.
Hi Kathy,
Thanks for your reply, I can now import my own textures.Is there a basic
tutorial for using textures?
In Studio choose Help-> Tutorials and look for the one you want there.
Thanks AiDon
