Applying the same effect to multiple images
Hi there,
I am new to Topaz Studio and I was wondering if there is an easy way to apply the same effect to multiple images. I am working on an image sequence and would like to apply the same exact effect on all of them. I can open all of them in Topaz Studio, but when it comes to the application of the effect, I have to select individual frames then apply the effect manually every time.
At the moment the only ways to achieve that are either to create a Preset with the current adjustments and apply that to all the images … or you can use the Copy all Adjustments/Paste all Adjustments options from the Adjustment menu at the bottom right of the workspace …
