Artifacts in zoom
Hey,
After saving the image in Studio Topaz - see the artifacts.
How to get rid of it?
Need to provide more information about what you were doing, such as:
  • What version of Studio are you using
  • Your system specifications
  • Standalone, or via other application
  • What is your original Image quality
  • What effects you applied
  • What save as settings you used
Then you may wish to upload the original image to a file sharing site so we can follow your process to work out what is wrong.
  • the latest download today (in the trial version)
  • Windows 10, computer fast a few years
  • alone and in Photoshop CC2017
  • very good (photo from Canon 5D III)
  • problem with every effect
  • standard settings
Need more help than that:
  • does your computer meet the minimum specified technical requirements?
  • Go to Help-> Graphics info , click to copy the information and paste it here please.
Do the artifacts show in Photoshop CC2017 before you call Studio through the filter menu?
Are you using a RAW image or a previously converted JPEG image in Studio?
  • Please post a screenshot of the image, before you apply an Adjustment, by clicking on 100% and then showing the particular area where you have the artifacts.
  • Then post another screenshot of the image with the same area showing at 100% after you apply a Adjustment.
  • no
  • the problem is with RAW files, jpg saved in photoshop, tif saved in Digital Photo Professional, also previously converted JPEG image in Studio.
Print Screens:
Thanks for this report! This is a known issue with large images in Topaz Studio. We have it on our to-do list to correct in a future update to the Studio application. Thanks!
