Constant Content Syncing
Hi, I use Topaz studio a lot as a plug-in to Affinity photo but after the last update every time I enter Topaz Studio it goes through a content sync which slows my workflow to a crawl. Is there a way to turn off the automatic sync and go back to the manual sync like it was before the update?
It is a known issue that is being worked on by the developers and hopefully there will be an update soon. If you want to add voice just raise a support request from the links above.
I was seeing the same thing and just thought my imagination was running wild. :confounded:
