It continues to apply a preset which I have cleared several times (Shift/Ctrl/R and the Undo Arrow!!!)
It’s driving me a little crazy…just a little!!!
That’s taking AI a little too far!
Jack, maybe there was only a little left to go. A new Topaz product in the works will help to recover sanity. Not yet ready, you can be a Beta tester. Have you tried the Reset Local Database (Help menu in Studio), it seems to answer a lot of issues?
That worked - lost all my Custom Effects - but nomore wrong application!!!
Obviously it is after the fact, but on the Topaz notes about resetting the local database it says you should save your effects out to a project file as the database sync is being modified.
Sorry about that Jack.
Some of the custom presets came back by themselves; and luckily the major ones I saved as TSPs!!!
Today after a DB Reset, I am getting an unwanted Image Layer Adjustment every step of the way!!!
