Can you change the size of the Mask Brush in Studio. If so, how? Thanks!
Looks as if they took it out of the latest build as it has worked for me in the past. There is a line where the size button is supposed to be, but the size button is gone now…Something to fix later I think…
Sorry I made a mistake. The size button for the brush to mask is the radius button. There is a softness button that is used also. The line was to delineate the section…whew…Just checked it again and it works as should…
Thanks! Works great. If it had been a bear it would have bit me
