Is there a video on masking in Studio? Is there a way to save several masks in one session for use in another session?
Thanks,
Sheila
Thanks,
Sheila
There are many videos, simply do a Google search for “masking in topaz studio” and you will get many youtube videos etc … one on the Studio blog is:
In answer to your second question NO, but it wouldn’t be useful unless you were going to use it on the same image which you can do by saving your work as a Project file and then when you reopen it to continue the image(s) and adjustments will be there for you to continue with.
Thanks Don. I should have figured that out myself!
Sheila
