After looking at Mond’s Foggy Morning picture I wanted to see if I could add fog to a fall mountain picture. Using Affinity Photo I add a layer filled with about 40% gray then set the blend mode to Hard Light. I then added a mask to that layer and applied a gradient to the mask so the top half would be fog and bottom would be clear, adjusted opacity to taste. After that I made a stamp (combined the layers) and went into Studio and used Impression to make the painting. Final step was Precision contrast to make it pop and show more detail.
Looks like success getting the foggy look. Very nice.
And thanks for including your process.
Best regards
Nicely done and thanks for the explanation …
Great job!
