…is open but off-screen. Using the Alt-Space and M for Move does not work; neither the cascading/stacking windows command nor the Win Button/arrow key. It also says in Task Master that 1-1-9 is not responding…
Win 10, i7 16Mb memory
It’s OK - for some very confusing reason it decided to open screen-left - my normal dual-monitor is screen-right… I adjusted the resolution and managed to catch the finest of edges and pull part of the frame into the main screen, where the Win+arrow combination brought it back to full-screen…
