Some Simplify Presets Not Working in StudioPR v.1.10.5?
Found some Simplify presets producing strange results in Studio PR v.1.10.5?
I’m not sure if these presets are working properly or it’s just me?
I find that with turning off the Adjustments_ it seems that the EDGES adjustment may be the problem?
Found these presets to have the issue:
Cartoon_Black Line Only_Colored Pencil Light on Black_ALL Line & Ink presets_Newspaper Print_White Line Only and Pony Espresso?
Sample images:
Original:
Line & Ink Preset sample: All the line & Ink presets look the same in the preset side panel?
Is there something I am overlooking or is this a bug?
Are you on a Mac or PC? Mine seems to set up different than yours when opening Simplify in TS. I tried two pictures to see if it was different on another image…WIN 10 Pro here. Did you also check the adjustments updates? Hope this helps.
Hi John,
Try “Check for Adjustment Updates” and if that doesn’t work raise a Support Request at the Studio link in the header.
Thanks for the input @Buckstop75
I’m on a Mac and my results are different than yours using Simplify in Studio?
Thanks @AiDon I did check Adjustment updates.
I just answered one of the Topaz techs on the other post I made on this same subject… will wait for his reply?
Simplify has got some ‘unfunctioning’ presets its true.
