Studio Not Updating On My Laptop
I noticed in the changelog that the most current version of Studio is 1.10.5. The version I am running on my laptop shows up as 1.8.5. When I went into help and did a check for software updates it indicated I was running the most current version - go figure! Would anyone know how I can force the update through? Would I need to uninstall the program and then reinstall? I haven’t had to do this in the past.
Just download the new installer from http://web.topazlabs.com and run that. But I would also uninstall before running the installer because there have been a lot of releases since then.
Cheers Don - downloaded and ran installer per your suggestion and all good now :). Really appreciate your help!
