Topaz Adjust crashes after opening it thru both LR and PS. The program will open and I can move sliders on the right side. As soon as I click on a preset on the left side, it immediately closes.This occurs in both LR and PS, so it’s a TA problem. I’ve uninstalled and re installed TA many times but it makes no difference. It used to work a few months ago so not sure what happened. Anybody have any ideas?
Hi,
Firstly go to your “%localappdata%\Topaz Labs\Topaz Adjust 5\Presets” directory and delete the following file:
- TopazPresetsDB
Then inspect the “My Collection” directory in the Presets directory and delete any presets with duplicate names.
To find the correct directory copy what is in the " " and paste that in the file explorer and press enter and you will be taken to the presets directory.
OF COURSE I am assuming you have Windows and you didn’t give any information about your PC.
I apologize…I have a MACBook Pro.
For all Topaz products check the file locations here:
https://support.topazlabs.com/hc/en-us/articles/200129096-Where-does-the-software-install-to-
Where do I find the Presets directory on my MAC. I went to Applications/Topaz Labs/Adjust but no presets directory.I also searched my MAC for it and it is not there. Thanks for your help. It is really frustrating.
From that article it looks like … User Library/Application Support/Topaz Labs/ and I guess it would be Adjust after Topaz Labs
Don’s info and file path above to find your Adjust presets is correct for your Mac.
