Topaz Impression command prompt options
Does anybody know about the command prompt options to be used for Topaz Impression?
If I start Impression from the DOS prompt (black screen):
Impression -f [file]
it reads the as an input without the need for its selection.
Perhaps, there are others like [output file], [filter to use], etc.
Thanks.
