When opening DeNoise AI (as a plugin from Photoshop), the opening ‘view’ (Singlie, split, side-by-side) is retained from the last use. But the ‘zoom’ is always reset to 100%, regardless of where its left. And the ‘Auto-Detect settings box’ is always set to ‘off’. I’m requesting making both those ‘sticky’ – allow the user to decide (via a preferences check box) whether to reset the view to default on startup, or to retain the last settings used.
