Hi, just a quick message. If you already own Simplify it may just look like it will work in studio automatically. If it does not don’t panic.
Open a photo try something. Does not work! Quite back to photoshop then it will ask you if you want to update Topaz Studio. Say, yes.
This will then quite Topaz Studio and update it. It will just take a few moments they try again and you should find it is now working.
Well at least that is what just happened to me. So I thought I would pass it on just incase it helps others.
