You should do a reinstall perhaps?
Getting so confused - update or reinstall?
Updated and all working… Thank you!
Reinstall, as it seems much of your software is missing!!!
Hey Don, I updated and all is just fine. The textures apply to the open image and I have the proper help menu and I am very pleased. Thank you so very much for your timely responses. I super appreciate it. Have a great week ahead. Kat from Toronto. Hey, if you are ever in Toronto I will buy you a glass of wine.!
