I have recently noted that if I crop in Studio and then take other steps the crop reverts to as opened. Can you only crop at the end of editing?
No crop can be done at any time, just have to click on Done when you are finished.
I you feel that the crop isn’t sticking at some point just outline the workflow (exact) that you see this happening.
Thanks for that quick response. I have been clicking on APPLY which is immediately under the image. I did not realise that DONE appeared way over in the adjustments panels.
