Hello;
I’m using Topaz Studio and when I open my Raw files, in this case Canon’s .CR2, Topaz Studio it is not recognizing my Lenses.
Hello;
Hi,
Note that lens corrections are applied automatically and you can see this if you click on the lens correction Icon where, if you want to adjust manually, you can turn off the automatic correction. This is a list of supported lenses as the LensFun database is used for lens corrections: Lensfun
See this image and, as with other products, not all lenses are automatically corrected.
Hi;
I’m doing exactly that, the image that I’m using was shot with Canon EF 25-105mm “L” f/4 and it appears in the list provided. When I press Lens Correction it shows the options for correction but not the Lens information or correction.
Are you sure you don’t mean the Canon EF24-105mm f/4L IS II USM, which is a new lens? You can see from this screenshot that the Canon EF24-105mm f/4L IS USM is picked up for me:
