Topaz Texture Effects 2 deletes lens info from EXIF
I’m using TTE2 as an external editor from LR CC which works really nice. However, there is one thing that really annoys me and that is the fact that the resulting image doesn’t have the lens info as part of the exif anymore; it’s blank instead.
Can you please fix that?
You may wish to raise a Technical Support Request at the links above.
In the meantime you can synchronize the EXIF info from the original.
