Did you know that MS Excel, Word, PowerPoint and Outlook can easily remove a background in an image? It is quite powerful and something that masking apps should aspire to do …
That is amazing, I had no idea. I just tested it out in Word 2010 and it did a great job, very easy. You can even save as a png. Thank you for posting this Don
I agree with Ricci … that is great and thanks for sharing Don
Wow. Thanks for the heads up Don…I just tried it on an image using the tools in Word…works like a dream…
Works in Office 365.
It may work better with objects that have clearly defined edges. Hair for instance is not easy to select.
I forgot it could do that, thanks Don!
