I am trying to add a person texture to a Digital Frames Mat. I imported the texture to my texture selection. The first time trying to add the texture brought up the texture, but in a raspberry color. I shut down and tried to use the texture a second time over an image and it worked fine. After closing and opening Topaz, my imported texture is agajn, raspsberry in color and adds the raspberry colored texture to my images. What am I doing wrong?
Make sure that you have the correct blend mode selected, for example Normal or Overlay are usually used for a JPEG and then adjust the opacity to your liking.
