How do I retain the subject in Sharpen when I add Background Noise Removal?
Sharpen didn’t select my entire subject so I added the rest of the bird as the subject. I added Remove Noise and selected Background. Would be nice if Background was defined as everything minus the user defined Subject.
I don’t think that’s how AI can work. I suppose what’s needed is the ability to invert masks and then copy and paste them.
Background is already an inverted mask of the AI chosen Subject. Basically, would be cool to have an option to save an override to the AI chosen subject that applies to all layers.
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea :slight_smile:
