Currently, if you want to increase screen real estate you can collapse the workspace panel which includes some tools (crop, heal, lens, mask, more tools, apply & duplicate) and thumbnails. I would suggest that it makes more sense to collapse the thumbnails only and retain the tools as I use duplicate and apply throughout my workflow. Thoughts?
I’m guessing the thinking is you can access those tools from the Tools and Image menus when the workspace panel is collapsed.
Best regards
